tranny trouble...
Are you sure the geometry is correct on the tv cable? at idle the cable should be ALL the way in with no slack, and at w.o.t. it should be ALL the way out.
bRAD..AKA..Soggy |
You need to change the geometry of where it attaches to to carb. I simply made an arm and positioned it so it traveled the correct distance. The farther from the pivot you go with the cable hook-up,the more it will pull the cable. I will post a pic of mine if you'd like.
pic of tv hookup
Hi zfuel, in my picture you can see the red arm that I made from flat bar to extend the geometry on the tv cable.
Brad...aka..Soggy |
The TV Plunger should be even with the Valvebody when the TV Cable is fully pulled.
You shouldn't have 'any' TV cable slack at Idle. What TV cable Bracket and Geometry corrector are you using? Examples: http://www.summitracing.com/parts/HL...n/?prefilter=1 http://www.summitracing.com/parts/SUM-700202/ Disconnect the TV cable, Engine idling, pull the TV cable out a dozen or so times & let it snap back. May clear any trash, sticking/binding TV or TV plunger. Now try to readjust the TV cable. Scroll down to where the 'Red' writing starts. Paragraphs 1-9, there're 3 Pics between 5-6: http://www.transmissioncenter.com/70...structions.htm |
That is the bracket I'm using. And geometry corrector p/n 20-121. I think maybe my throttle attachment may be a slight bit too high? I had to engineer a spot for it, I'm headed out to fix it now and see if it works then
Looking at Holley's instructions, the Throttle cable should be connected higher up on the Carbs' Linkage, not on the TV corrector.
>>> http://static.summitracing.com/globa...-199r10345.pdf |
| 700r4 shift problem | chewyscool | Transmission - Rearend | 3 | 02-23-2010 06:06 PM |
| 700R4 2-4 shift problem | 90GMCVortec | Transmission - Rearend | 9 | 04-12-2008 09:17 PM |
| 700R4 Shift Problem | chevy_power427 | Transmission - Rearend | 14 | 10-25-2007 08:47 PM |
| 700R4 Tranny Shift Problem | riesman20 | Transmission - Rearend | 2 | 10-13-2006 10:21 PM |
| 700r4 shift problem,1st to 2nd | root | Transmission - Rearend | 2 | 10-19-2003 11:31 AM |
