700R4 shifter mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2012, 04:47 PM
700R4 shifter mount
Hi,
Can anyone tell me how a floor shifter from an early '90s Camaro is mounted in the stock configuration. Is the shifter itself mounted to the floor board, or the tranny.
I'm looking at a used shifter on ebay to transplant into my project.
From the pics, it looks like the shifter mounts to the floor and the cable goes through and hooks to the shift lever, if this is the case then the transplant should work.
Right?
Thanks
Old 01-02-2012, 04:54 PM
poncho62's Avatar
Wiki Edits: 5
I am guessing this is an automatic trans?
Then, yes that is likely the case.
Old 01-02-2012, 04:58 PM
Yes, it is an auto tranny.
thanks
What is bestest shifter for 700r4 rwruther Transmission - Rearend 3 10-26-2009 01:15 AM
700r4 torque arm mount in 1950 F1 lelshaddai Transmission - Rearend 9 07-08-2008 10:54 PM
700R4 w/Lokar shifter help 39chevy Transmission - Rearend 2 03-31-2004 03:49 PM
3 duce 700r4 tv cable mount anglia48 Transmission - Rearend 2 07-15-2003 12:16 PM
700r4 shifter which one to get fire power Transmission - Rearend 4 05-16-2003 08:04 PM
