700R4 shifting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 10:14 AM
I have a 1983 700R4 that I put into a 1927 Roadster 350 engine shifts great from first to second and drags from second to first. What can be the problem?
Old 10-25-2010, 05:25 PM
SSedan64's Avatar
Need more Info, explain>> (Drags from 2nd-1st)??
Old 10-27-2010, 07:38 AM
700 R4
I meant to say it drags from second to third. If you back off the gas then step on the gas again it will shift
Old 10-27-2010, 06:38 PM
scrot's Avatar
Again, "drag"?
Old 10-27-2010, 07:57 PM
SSedan64's Avatar
So it doesn't want to shift 2nd to 3rd? A delayed shift or hanging up in 2nd gear.
May be the TV/ThrottleValve binding/sticking in the Valvebody. With the Engine idling give the TV cable a dozen or so full pulls & let it snap back, then readjust the TV cable & test.
700r4 shifting problems foogan Transmission - Rearend 17 10-26-2010 09:12 AM
700r4 problem jasontay Transmission - Rearend 4 07-02-2008 06:31 PM
95 Z71 700r4 (I think) problem Chevyboy454 Transmission - Rearend 6 04-15-2008 12:34 PM
700R4 Shifting problems yellabelly Transmission - Rearend 1 11-17-2006 10:43 AM
700r4 shifting problem 89chevstepside Transmission - Rearend 0 05-08-2002 02:10 PM
