700r4 shifting problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2011, 04:38 PM
I have a 1989 gmc 4x4 with the 350 engine and a 700r4 the trans got water in it and now will not shift out of first gear and I already changed the filter what could be the problem so I can fix it
Old 10-04-2011, 01:29 AM
SSedan64's Avatar
Water in a Trans = BAD.
Could have caused corrosion on any number of parts, Shift valves etc...
The Bonding agent used to secure the Clutch friction material to the Clutch plates & Band is water based, if all the water wasn't removed the 1st time the Trans gets Hot it can steam the clutch material off.
Old 10-04-2011, 10:23 AM
Depending on how long the water was in there, it could have caused several problems. As mentioned already, water seperates the glue that holds the friction material to the steel backing plates. The other big possibility is rust. The 700 uses a cast iron valve body and has steel valves. A valve could have stuck. It's also possib;e that the governor has stuck. How did you get the water out of it?
Frank
700R4 Shifting problems ChevySDime385 Transmission - Rearend 9 11-26-2010 08:25 AM
700r4 shifting problems foogan Transmission - Rearend 17 10-26-2010 09:12 AM
700r4 shifting problems schottout Transmission - Rearend 1 12-12-2009 07:44 AM
700r4 shifting problems? problems Transmission - Rearend 7 12-20-2006 07:15 PM
700R4 shifting problems Hotrodpickup Transmission - Rearend 4 04-05-2006 08:15 AM
