700R4 shifting problems
I'm new to this board, but joined in hopes that someone could offer some help/suggestions. Have a 700R4 hooked to a 383 stroker motor in a 69 C-10. The TV cable is adjusted right ( I think) because the trans shifts crisply in the ranges it should under moderate throttle. The problem occurs under WOT, the thing sssslides into the next gear, not a firm shift. Anybody know whats wrong?
Hi Hotrodpickup,
Is the trans stock or have you had it built up? If you feel everythhing is strong in trans go back and recheck your TV adjustment, pop up the retainer and accelerate to WOT (engine off of course) and then clamp down retainer. You can miss this adjustment pretty easy if you don't get WOT. Jack |
The trans is rebuilt, to what level I don't know. Has a 2500 stall converter. I did not adjust at WOT so I will try your suggestion. Thanks for the help.
700r4
Try Installing A Corvette Or Billett Servo This Will Crisp Up The Shift
| 700r4 governer gear problems | chevcamz28newbie | Transmission - Rearend | 3 | 03-13-2006 07:26 PM |
| 700R4 Shifting Question | jdhoggg | Transmission - Rearend | 5 | 06-01-2005 10:00 PM |
| 700r4 shifting | 68novafan | Transmission - Rearend | 1 | 03-28-2005 05:36 AM |
| 700R4 Shifting issues | fruiz | Introduce Yourself | 3 | 11-18-2004 01:54 PM |
| camaro z 28 tranny shifting problems | chevcamz28newbie | Transmission - Rearend | 8 | 07-22-2003 07:43 PM |
