700R4 Shifting Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 07:21 AM
jdhoggg's Avatar
New Member
I have a car with a 700R4 tranny that short shifts from first to second. (It shifts at about 4500rpm.) In all the other gears, it shifts around 6200rpm. How can I "cure" the short shifts?
Old 05-30-2005, 09:07 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what year 700 tranny? Sounds like you leave the shifter in "OD" position?
If the 700 is a early (pre mid-1987 tranny) , install a .296 low / reverse boost valve. This will help hold 1st gear longer
Old 05-30-2005, 10:20 PM
jdhoggg's Avatar
New Member
Not sure of the year....it's not computer controlled though. I actually have a B&M ratchet shifter in the car and with it in 1, all the way back, it still short shifts. I would love to be able to rev the car on up. I'll have to take it to a local shop to see how old it is. (Came with the car when I bought it.) If it is old enough I'll have to try your idea about the boost valve. Thanks for the advice...I am new to the muscle car game. Got burned out on turbo 4 bangers and decided there is really NO replacement for displacement...LOL
Old 05-31-2005, 09:01 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
since you post that the tranny shifts to 2nd while the shifter is in "1", you have an early design tranny & valve body( pre 1987)...
install a .296 diameter low / reverse boost valve to delay this up shift.
there are two boost valves, a .500 is the main boost valve and the .296 l/r work together well
Old 06-01-2005, 09:48 PM
jdhoggg's Avatar
New Member
thanks for the info!!!! will look into getting what i need tomorrow after work.
Old 06-01-2005, 11:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
looking at my post , I did not make it clear.....
the .500 main boost is an after market boost valve.
The .296 low/reverse boost valve is still availible from GM
np203 shifting question gleveric Transmission - Rearend 4 02-16-2005 05:06 AM
700R4 Mounting Question mike bryan Transmission - Rearend 6 11-05-2004 06:14 PM
700r4 band question chevcamz28newbie Transmission - Rearend 0 08-05-2003 01:46 AM
700r4 camaro shifting chevcamz28newbie Transmission - Rearend 1 07-21-2003 11:21 PM
Another 700R4 Retrofit question dpjmw Transmission - Rearend 1 01-01-2003 04:07 AM
