Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 shifting too quick
Old 03-21-2013, 09:44 PM
gonzo08383's Avatar
gonzo08383 gonzo08383 is offline
Last journal entry: brakes
my 700 did the same thing when i had the cable too loose. if you try everything else and still shifts too quick just pull more tension on the tv cable and set it. by more tension i mean just a wee bit. make adjustments by 1/16th of an inch at a time and drive it just a ways too see if it helped. dont drive it too far just in case. you can burn up a 700 easy if that cable isnt right. if you have to adjust the cable any more than 1/4th inch either direction STOP IMMEADIATELY. let the trans guys deal with it at that point. you shouldnt have to adjust it far to get the shifting right. mine had to move less than 1/8th inch to get the line pressures right. too much slack in the cable had me in OD at 35mph. not good.
