UHHH,yea...Take it back to the shop that did the work.
Oh guess I should finish the story. The car was "rebuilt" in 1999 which is when this transmission was done. Its sat most of the time since then, it was only a spare vehicle for the previous owner. Anyways, the warranty is long gone and I dont even know if that shop is still around or not.
I hate to say anything, because i don't know much about the 700, but i'd guess like the average joe. I think you tranny is set up for a vehicle with a different gear ratio so it shift to soon in every gear. What is your rear gear ratio? You may have to call one of the rear tranny experts, but they will need to know alot about your vehicle and the tranny as far as what year it is.
I also vote for the governor.
B&M 20248 B&M Governor Recalibration Kit Haven't done mine yet but will probably fix it this summer. |
My guess is that you're both probably right. The governor is set for a different vehicle. Problem is that I dont know what vehicle the trans came from, or what its gear ratio was, nor do I know what the current vehicle gear ratio is. I need to figure that out so I can order the correct speedometer gear. Its off by about 7mph. Anyways. I need the trans to shift around 5,000 or 5,500. Stock red line for this engine is 5,600 RPM. This car will kick some butt with an appropriately shifting transmission. It has alot of get up and go to it, but if you shift it manually and rev it up higher, it goes even better. |
the governor is under the press on round cover near rear of main trans case (if you dont know) ... You need more room to install the cover back on, than to remove it. Check that before you blast the cover off with a screw driver and hammer. On a 700r4 / 4L60 trans, the valve body is calibrated with the governor to some degree. Different strength springs on the the shift valves , different size shift valves.. Do Not take this to mean that each valve body is calibrated with each governor. What I am saying there are some variations on the valve body too. The recalibration kit is best option for most DIY guys, rather than grinding on the weights. Inner governor springs affect shift timing the most at 35mph and lower... the inner weights affect shift timing most above the 35mph. The springs and weights work together, I am just pointing out what affects what at a certain mph for a FYI to you work with..... gear ration , tire size affect that stuff too this si not a hard line, it is a guide line on the 35 mph comment.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
my 700 did the same thing when i had the cable too loose. if you try everything else and still shifts too quick just pull more tension on the tv cable and set it. by more tension i mean just a wee bit. make adjustments by 1/16th of an inch at a time and drive it just a ways too see if it helped. dont drive it too far just in case. you can burn up a 700 easy if that cable isnt right. if you have to adjust the cable any more than 1/4th inch either direction STOP IMMEADIATELY. let the trans guys deal with it at that point. you shouldnt have to adjust it far to get the shifting right. mine had to move less than 1/8th inch to get the line pressures right. too much slack in the cable had me in OD at 35mph. not good.
| 700r4 not shifting right | lowriderr9 | Transmission - Rearend | 8 | 12-24-2012 11:47 PM |
| T-400 shifting too quick | sscanrun | Transmission - Rearend | 22 | 12-23-2012 07:31 AM |
| 700r4 shifting | 85impala | Transmission - Rearend | 6 | 11-30-2012 09:48 AM |
| 700r4 shifting | 123pugsy | Transmission - Rearend | 11 | 11-27-2006 07:39 PM |
| Auto shifting to quick! | chevelle327 | Transmission - Rearend | 6 | 11-25-2002 06:57 AM |
