700r4 shifts in between gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2011, 11:56 PM
codyglock's Avatar
Ive searched all over the internet and havent found anybody with any similar problems. It seems like the only time this problem will happen is after either I go full throttle or when I shift into neutral or 3rd (while driving). After doing that when cruising doing 60 my car will downshift into 3rd gear and wont upshift until I give it throttle and make it accelerate, but usually as soon as a I let off, so I can just do 60, it will go right back into 3rd gear (it will also do this in town doing 25-30). It will have this problem the time that I drive it when I go full throttle or shift into neutral or 3rd, and the next time I drive it after that. But then the time after that when i drive it, it will drive completely normal again. any suggestions or similar experiences?
Old 08-05-2011, 04:58 AM
cadmanof50s's Avatar
68 Camaro Convertible, 327 RS
Cody,
I don't mean to insult you but are you sure that it is going into third? Or possibly is it the TCC unlocking that you are feeling?
Vic
Old 08-05-2011, 06:53 AM
tnsmith10's Avatar
when will it rain???
if its down shifting on its own when you let off the throttle, then more than likely the throttle valve is sticking in the valve body. when is the last time any maintenance has been performed? how many miles on the vehicle?whats the level and condition of the fluid?
Old 08-05-2011, 09:52 AM
codyglock's Avatar
Originally Posted by cadmanof50s
Cody,
Vic
well im not completely sure but the rpms go from about 2500 to about 3500.
i just replaced the pan gasket and the gasket for where the kickdown cable goes in. im not sure how many miles are on the transmission, its currently in a volvo station wagon and thats the way i bought it. the fluid appeared to be in good condition and i put it at the right level when i changed the pan gasket which was only a few days ago. *and this problem was happening before i changed the gasket
Old 08-05-2011, 03:07 PM
codyglock's Avatar
oh and I've also noticed it will do this after driving for a while, say longer than 20 min. I don't know if this is any more help.
Old 08-07-2011, 05:11 AM
SSedan64's Avatar
Sticking/binding TV/ThrottleValve or TV Plunger normally happens after the Trans gets up to operating Temp.
As "Tnsmith10" suggested this may be your problem.
http://www.sonnax.com/product-lines/...ion/parts/1614
Old 08-07-2011, 12:15 PM
codyglock's Avatar
so what could i do to fix this problem?
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-10-2011 11:00 PM
700R4 Shifts Too Soon 10mikeymike Transmission - Rearend 5 11-19-2009 07:20 AM
700R4, only shifts @ WOT Hotwire Transmission - Rearend 13 09-05-2008 08:14 PM
700r4 shifts pink63impala Transmission - Rearend 7 03-16-2005 04:57 PM
700R4 Shifts Keppie Transmission - Rearend 6 07-16-2002 11:48 PM
