700r4 ... shifts late to over-drive
i have a 700r4 that 90% of the time wont shift in to overdrive if i hit 70mph it will and i was told it had a shift kit when i bought the truck84 chevy could it be a vacume problem or what could it be any advice would help im not a trans person thanks eric
the other 2 shifts are timed / shifting correct speeds. Do the shift points increase in speed as you step on the gas pedal harder? to verify ; the shift to over drive is late .... Not the converter clutch lock-up? could be several items with the late shift to Over drive; sticky shift valve sticky or worn inner TV valve in the v-body some person installed a stiffer spring into the OD shift valve assembly in the v-body
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Thanks again Crosley! |
so there is not supposed to be a vac on the tranny on a 700r4 because there is one going to the modulater valve and yes shift points do change at higher speeds
700?
Where on the trans is this modulator located?
A 1984 chev truck could have a t-350c trans. this is a 3 speed trans with an internal locking converter clutch. Your truck may have been built with a 700r4 and the 700 was replaced with a 3 speed automatic.
the truck came from the factory with a v6 and a 3 speed trans but the guy i bought it from put in a v8 and he said it was a 700r4 but when i hit 65 it shifts in to 4th gear so it really cant be a turbo350
the modulater valve is on the passenger side at the back
Perhaps a t-350C or a t-250C trans is in the truck with a lock up torque converter. as i posted before If the trans has a vacuum modulator on it, then it is not a 700r4 trans,. NONE of GM's over drive transmissions have a modulator on them.... not the 200-4r , 700r4 , 4l80e
Hey, crosley is right. A 700-R4 runs via TV cable, or "kick-down" cable that ties to your throttle linkage. That last shift your feeling is prolly a lock-up converter kicking in. They can start acting funny and go bad. However, if your vehicle puts a significant load on the tranny at highway speed, the converter will purposely hesitate to lock-up. They work off of vacuum and load. When your throttle is to far open with a significant load on the tranny, your vacuum is down and your load is up, so the converter is un-locked. When the vaccuum goes up and the load goes down, it will lock. Your setup may be hung in the middle of these situations. Too high of a gear ratio can cause this, especially at highway speeds, but it could just be a bad converter.
thanks for all the info guys the truck has 6cylinder gears in the rear end
6-cylinder gears? If you mean the truck was geared for a 6-cyl engine, that doesn't mean a whole lot. It could still have a big number of different axle ratios, or they could even have been be changed by someone.
| 700r4 help-any chevy guys? | briansansone | Transmission - Rearend | 4 | 02-24-2006 01:30 PM |
| 700r4 shift times is this ok? | evltwin | Transmission - Rearend | 1 | 04-23-2004 06:22 PM |
| 700r4 | camarofreek | Transmission - Rearend | 2 | 10-10-2003 07:38 PM |
| 700r4 shifts in and out at shift points? | dpjmw | Transmission - Rearend | 11 | 03-30-2003 12:32 PM |
| crazy shifts | ss crazy | Transmission - Rearend | 2 | 10-14-2002 12:25 PM |
