700R4 Shutter Noise when Accelerating - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 01:20 PM
Cole's Avatar
Now if I could just afford Gas
Last journal entry: Breaking Bad on the Camaro
I have a new 700R4 transmission that has what I can only describe as a "Slipping" or "Shuttering" noise when I get on the accellerator. I am using the TV cable system on it with a 350 HO engine. Has anyone seen this before? I stopped driving the car right away so I do not think I did any real damage.
Old 02-24-2009, 09:07 AM
SSedan64's Avatar
What gear or gears does this happen in?
Are you using the correct TV cable geometry corrector on your carb linkage?
Old 02-24-2009, 04:42 PM
Cole's Avatar
Yes, in all gears and I check the linkage geo 3 times. I think it's a valve body problem becuse when it heats up is the only time it does it so I pulled on the TV cable only and the pressure gauge reading did not increase at all so I am taking it back to the shop :o(
But thanks for helping!!
Old 02-24-2009, 06:03 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I had a new trans do that once.the trans guy told me there is a small valve inside when it sticks it shutters.He had me buy some stuff called shutter stop and it did but i sold the car about a year later it was still working fine .after that i really dont know.just trying to help. cole
700R4 noise..Crosley? 302 Z28 Transmission - Rearend 6 02-24-2009 07:52 AM
700R4 Noise in Reverse oldcarguy36 Transmission - Rearend 6 05-14-2008 05:39 PM
700r4 clicking noise in 1st MetalDrgn Transmission - Rearend 2 10-12-2006 12:04 AM
700r4 2-4 grinding noise AngliaBob Transmission - Rearend 1 05-14-2006 05:21 PM
Rear end Noise While Accelerating Auto-Part Transmission - Rearend 9 11-10-2003 10:36 AM
