700r4 Skipping 2nd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2003, 04:52 PM
I have a 84 Camaro Z28, 355ci, 700r4......Has been working fine other than it won't stay in 1st gear over about 4000-4500rpms.....think I have a fix for that, but, all of a sudden it won't shift into second gear anymore....gos straight to third gear after hanging in first way longer than it should.......If I try to manual shift it, it's like hitting neutral.....same on down shift.....like I said...never slipped at all....hard to believe for a 700r4 that gets tortured with NOS........didn't expect it to last long before a th350 swap, but didn't expect it to go like this.....maybe a stuck valve???
Thanks for any thoughts on this......Mark
Old 08-06-2003, 07:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
I will guess that reverse still functions.
you may have broken the band, a bad & leaking accumilator for 2nd gear, or a problem with the servo for 2nd.
Early upshift in manual low gear on your 700r4 is corrected with a larger low/reverse boost valve. A .282 or .296 valve will cure the early upshift out of first gear with the shifter still in low .
Old 08-07-2003, 04:44 AM
Thanks Crosley
Reverse works great.......and another thing I have noticed is that when I pull on the TV cable with the car idling in neutral....feels the same as when the car is turned off.....used to feel it tugging back as I pulled on it before....also when it finally shifts out of first gear, it sounds like it hits second for a nano-second..then right to third..........Thanks guys......Mark.
Old 08-07-2003, 08:11 AM
tnsmith10's Avatar
when will it rain???
700r4
yea, it sounds like either the servos seals died, or the band broke.
Old 08-07-2003, 03:52 PM
Thanks for the help.........guess it's time for the th350 swap.......will check the servo, but, if it's a broke band then will have to put her down long enough to have my th350 rebuilt and throw it in.......Way better off in the long run anyway....Thanks again........
