700r4 slipping - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2012, 10:20 PM
700r4 slipping
i have a 86 k-5 blazer with 700r4. just did my first rebuild , reinstalled trans, now it slips in reverse real bad, it engages and will back up untill there is a load (up hill) then slips. forward gears are not as bad. any suggestions?
Old 04-19-2012, 12:53 AM
SSedan64's Avatar
Was the TV Cable adjusted correctly?
Pressure test done?
Old 04-19-2012, 01:11 AM
700r4 slipping
hey thanks for the response , i followed the directions from other postings on adjusting the tv cable, so i hope i have adjusted it properly,as far as pressure testing , i have not done this because i am not sure how to go about doing this or what special tools will be needed , any help would be greatly appreciated. thanks
Old 04-19-2012, 04:15 AM
SSedan64's Avatar
Look thru these, should find what you need for Pr. testing. I've posted links in a few Threads with places to find cheap 0-300psi. Test gauges etc..
http://www.hotrodders.com/search?q=P...ion-rearend%2F
The 700-R4 & 200-4R Trans use the same Pump & test methods.
If you don't find what you need I'll post more.
700r4 only slipping in 2nd gear for 1-2 seconds? vortec86z29 Transmission - Rearend 2 02-27-2012 07:20 PM
700r4 Slipping In Drive EDDIE5394 Transmission - Rearend 4 04-19-2009 08:33 PM
89 700r4 tranny slipping Lil_Victory Transmission - Rearend 7 08-02-2005 01:08 PM
700R4 Slipping StudebakerMatt Transmission - Rearend 2 02-13-2005 11:11 AM
700R4 with slipping converter clutch CleviteKid Transmission - Rearend 1 08-28-2004 05:56 AM
