700r4 Slipping In Drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 09:24 PM
i BOUGHT A 700R4 USED THE GUY SWORE THAT IT WAS GOOD. PUT IT IN AND IT MAKES A BANGING NOISE AN IT SLIPS IN DRIVE JUST ENOUGH TO NOTICE OTHER THAT THAT IT DRIVES FINE. i DID READJUST THE DETENT CABLE BUT IT STILL IS DOING IT ANY ADVICE OTHER THAN A REBUILD. i AM TAKING IT TO AMCO TO BE CHECKED OUT TUESDAY THANKS
Old 04-19-2009, 06:57 AM
Change Filter
Smell for burnt fluid
Check fluid level at operating temp and in park
Push "Caps Lock" button once.
Old 04-19-2009, 09:22 AM
302 Z28's Avatar
That cable on a 700R4 is NOT a detent cable, it's a TV cable and it absolutely is the life of a 700R4. If is not adjusted properly it will fry the 700R4 in very short order.
Old 04-19-2009, 05:46 PM
fluid is fine tv cable is fine.
Old 04-19-2009, 08:33 PM
Crosley's Avatar
Wiki Edits: 1659
Sounds like a worn out trans if all checks out OK
A few Questions on a 700R4 swap. zbhover Transmission - Rearend 2 02-24-2009 05:13 PM
TH350 STILL slipping after long drive 87442lover Transmission - Rearend 10 01-02-2007 05:19 PM
TH 350 Slipping Houman SS '70 Transmission - Rearend 10 12-23-2005 07:43 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
