700r4 slips , grinds - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2009, 09:41 PM
700r4 shifts all gears in overdrive slipes and grinds when shifting manually 1st 2nd and 3rd .
Old 02-12-2009, 06:00 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Ok I have my crystal ball on the table and it says, that is no way for your transmission to be working, matter of fact it says it is not working..
hope this helps answer your question...
Old 02-12-2009, 06:46 AM
SSedan64's Avatar
In other words it's about to come to a grinding halt.
Old 02-12-2009, 10:17 AM
red4x4
makes no sense overdrive works all gears and also down shifts as long as its in OD.
Old 02-13-2009, 09:13 PM
You might need to adjust your linkage. I had to do that on my buddys 74 nova.
Old 02-13-2009, 09:46 PM
Crosley's Avatar
Wiki Edits: 1659
What is the history of this 700r4 transmittin?
Mileage?
recent rebuild or parts replacement?
Any service work performed if an older transmission?
700r4 slips from 2nd to 3rd gear scott29 Transmission - Rearend 4 12-07-2008 02:06 PM
700r4 tranny slips jerryb Transmission - Rearend 4 12-05-2006 12:54 PM
700R4. No 2nd Gear, Slips in OD CedarGrove Transmission - Rearend 3 07-29-2006 12:00 AM
700R4 slips in reverse rdjern Transmission - Rearend 6 08-08-2005 08:24 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
