-   -   700R4 Slow to shift into Reverse (http://www.hotrodders.com/forum/700r4-slow-shift-into-reverse-109748.html)
rudeg 02-23-2007 09:37 AM
If this is a common problem does anyone know what's happening. It seems worse when vehicle is cold. 1986 Chev Silverado 305.
Grant
Crosley 02-23-2007 05:19 PM
Grant
what is the history of this tranny?
original mileage on it? Has it been rebuilt before?
there are two areas in the trans that can cause a no / weak reverse.
Sounds like hard internal seals since it is worse when cold
rudeg 02-23-2007 10:58 PM
700R4 slow to shift into reverse
Hi Crosby, thanks for the reply. As far as I know it is the origional tranny and never been touched. 208,000 Km. Never been out of Alberta,Canada. Some pretty cold winters.
Grant
GMCTRUCKS 02-24-2007 12:42 AM
Trans
Add a bottle of transmission cleaner that's what I did on mine it cleaned out the valve body. Good Luck!
rudeg 02-26-2007 10:09 PM
Thanks alot, I ll give it a a try.
Grant
