700R4 Slow to shift into Reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2007, 09:37 AM
If this is a common problem does anyone know what's happening. It seems worse when vehicle is cold. 1986 Chev Silverado 305.
Grant
Old 02-23-2007, 05:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Grant
what is the history of this tranny?
original mileage on it? Has it been rebuilt before?
there are two areas in the trans that can cause a no / weak reverse.
Sounds like hard internal seals since it is worse when cold
Old 02-23-2007, 10:58 PM
700R4 slow to shift into reverse
Hi Crosby, thanks for the reply. As far as I know it is the origional tranny and never been touched. 208,000 Km. Never been out of Alberta,Canada. Some pretty cold winters.
Grant
Old 02-24-2007, 12:42 AM
GMCTRUCKS's Avatar
Trans
Add a bottle of transmission cleaner that's what I did on mine it cleaned out the valve body. Good Luck!
Old 02-26-2007, 10:09 PM
Thanks alot, I ll give it a a try.
Grant
700r4 trans shift problem daddy358 Transmission - Rearend 2 10-26-2006 03:56 PM
700R4 shift points AngliaBob Transmission - Rearend 3 04-20-2005 11:00 PM
700r4 won't shift at WOT Alex99 Transmission - Rearend 39 02-15-2005 09:08 PM
Reverse shift pattern brainsboy Transmission - Rearend 3 06-29-2004 02:51 PM
ford aod reverse shift snoman Transmission - Rearend 2 02-17-2004 06:38 PM
