Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 Slow to shift into Reverse
Old 02-23-2007, 05:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by rudeg
If this is a common problem does anyone know what's happening. It seems worse when vehicle is cold. 1986 Chev Silverado 305.
Grant
what is the history of this tranny?
original mileage on it? Has it been rebuilt before?
there are two areas in the trans that can cause a no / weak reverse.
Sounds like hard internal seals since it is worse when cold
