700r4 soft shift's between gears at WOT ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2011, 04:17 PM
It's newly rebuilt 1991 Th700r4 from S10 Blazer, currently behind a mildly hopped up 350 SBC in a lifted Jeep.
It has a Trans go shift kit and everything new (that needed replacement, The trans had burnt 3-4 gear set)
The problem that's now is that it shift's fine (crisp, late and hard) at moderate acceleration when in O/D, D gears. but when you apply some gas from start through gears it shift's very softly into gear's, almost like it's slipping, But when i shift it manually between 1-2 it's very firm,
If you need any more information please ask. 700 Automatics are not my favorite at the moment But I hope it will be ok some day.
Best regards.
Old 07-29-2011, 09:37 PM
could this be a bad governor ?
I have the TV cable set up right, with the correct holley TV cable brackets.
Also it seems that it won't go into O/D until warmed up...
Regards
Old 07-30-2011, 06:47 AM
tnsmith10's Avatar
when will it rain???
Best regards.
too much tv pressure, and incorrect governor calibration would be my guess with what you explained.
you can actually have the tv cable pulled to tight where the shifts at WOT will actually get softer.
i recommend that you reset the tv cable so that its just barely tight at WOT and then get a governor recalibration kit to dial in the WOT shift points. gl
Old 07-30-2011, 07:03 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since you mention the 700r4 is from a S-10 Blazer... during the rebuild was the boost valves upgraded? What servos are used for the 2-4 band?
You may not know this if the trans was rebuilt in a shop
Modified 700R4 has a soft 2-3 shift. qwkswede Transmission - Rearend 24 11-14-2014 11:23 PM
700r4 .. no 3rd or 4th gears deel2u Transmission - Rearend 2 12-27-2006 09:49 AM
700r4 has no 3rd or 4th gears mattgabe Transmission - Rearend 5 06-27-2006 07:59 PM
700r4 and 4.10 gears. Siggy_Freud Transmission - Rearend 1 12-09-2005 08:20 PM
700r4 soft shift MDFbodies Transmission - Rearend 3 06-22-2003 08:04 PM
