700r4 speedo gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2013, 11:00 AM
jeffmc's Avatar
jeff mc
Last journal entry: 1941 Dodge Custom
700r4 speedo gears
To make a long story short, If my output gear for my speed o cable is red,do I need a red drive gear also? ( Output being the gear on the sensor and the drive gear being the gear on the trans out put shaft)
Will another color work? I understand different colors have different number of teeth on the gear ,but I'm using a electronic gauge that is adjustable ,so can I mis match colors?
Also Its a 1987 700r4 trans .
Thanks
Jeff
Old 02-15-2013, 09:34 PM
SSedan64's Avatar
Not really sure, I haven't delt with Electro. much. It may work if the Gauge has enough adjustment.
Gears:
Transmission Speedometer Gears
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
Old 02-17-2013, 02:27 AM
Wiki Edits: 85
There is no such thing as mis-matched colors for speedometer gears. Seldom will both gears be the same color.
All that matters is that the gears work together to show the correct speed on your speedometer head.
Old 04-02-2013, 07:28 PM
the colors of the gear will depend on your combination of rear axle gear ratio and rear tire size.
I used this calculator on TCI's website to figure out what combo of gears I needed to make my speedo right when I swapped from 2.73's to 3.55's...
Speedometer Gear Calculator and Charts - TCIŽ Auto
after getting busted for doing 68 in a 50 cuz my speed said I was doing 90.. it was time to fix it.. lol
Hard to find 41 & 15 tooth speedo gears 700r4 elcaminodragster Transmission - Rearend 8 09-12-2012 07:43 AM
speedo gears wiseguy Transmission - Rearend 5 11-27-2010 09:23 AM
??? ON speedo gears 1972bigblockchev Transmission - Rearend 6 05-27-2008 03:29 PM
speedo gears sapsz28 Transmission - Rearend 4 09-18-2007 10:27 PM
TH 400 Speedo Gears rs67ss Transmission - Rearend 5 04-03-2005 11:58 PM
