700r4 speedo meter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 07:27 PM
Last journal entry: Doors and Hood
700r4 speedo meter
I have a 700r4 and just learned that there is a electronic sender for the speedometer. How do you install one of these units in the trany. I'm guessing they are expensive. Also can I find a cable for a original speedo out of my 48 F1 to the 700r4???
Old 02-18-2012, 08:11 PM
rick 427's Avatar
Last journal entry: The Cheetah
assuming its not an electronic trans...you can get an earlier ''screw in cable'' type 700 housing,gear,and hold down clip and swap out the electronic set up thats in there now,again,assuming there is a plastic speedo gear on the electric housing,and not a magnetic pick-up....as for the cable,one from a 48-56 ford 4 speed I believe will work in the dash speedo and trans end.
Old 02-18-2012, 08:45 PM
rick 427's Avatar
Is it a steel gear on the output shaft??
Old 02-18-2012, 09:54 PM
Crosley's Avatar
Wiki Edits: 1659
First photo shows a round metal disc (on left) that may be on your output shaft. Is that what you have or not?
Second photo shows speed-O parts needed to convert from eleectronic speed-O to mechanical if that is what you ask. Speed-O parts need to match your application , there are some minor differences.
Old 02-19-2012, 08:38 AM
mechanical speedo
Hey Thanks for responding, my 700r4 has the set up of your second pic. So what do I get to make it a electronic sender. Is there a attached unit that goes on top of the existing mechanical.
Old 02-19-2012, 09:12 AM
rick 427's Avatar
ok...ya lost me ...i thought you wanted a cable type,so you can use your 48 speedometer,and if thats the case,use your existing set-up in the trans ,with the cable I mentioned,and your 48 speedometer will work.
Old 02-19-2012, 09:14 AM
Crosley's Avatar
Wiki Edits: 1659
Here is a link to Jags that run ... they offer various speed sensors for cable operated stuff.
Or , you can install the electronic speedo meter stuff in first photo of my other post.
You will need to know what pulse rate for your application / year of vehicle. If you are using aftermarket guages, you need to knoww what those gauges operate on for pulses per mile
Old 02-19-2012, 09:28 AM
48 F1 speedo
Hey thanks Rick, I'll go with the cable. I was looking at some third market gauges and found they sell mech. and elctronic. thanks fo the info.
Old 03-06-2012, 05:48 AM
Guys I hate to jump in here but I need to fix my speedo mine is electronic the one in the first pic and I need the cable setup .I'm running 3.73 and 25.6 tires
Old 03-06-2012, 07:35 AM
Thanks for the pics crosley posted I have one been hear in the shop the whole time now I just need to figure out the tooth count
Old 04-03-2012, 10:04 PM
rick
Hey rick, you are correcto on the f5 cable, found one on e-bay for 19.95.
fits fine on the 700r4.. solved one of the many problems on my truck. thankx
Old 04-03-2012, 10:39 PM
rick 427's Avatar
Your welcome...it's good to see that it worked out for ya.
Old 04-14-2012, 01:33 AM
this has recently got very easy
i had a similar problem, or so i thought, with the 545re dodge 5 speed trans behind my late model hemi i'm putting in my '24 dodge coupe. then i found out that they make a gps device that you wire to your electric speedometer. the unit costs just over a hundred bucks, and solves a big problem. i'm using a winters championship quick change rear end, so this will be very helpful. the sensor reads the speed of the vehicle, not the speed or pulses of the driveshaft, so no matter what gears you're using, it'll always read right.
VSS to cable speedo on 700R4 Thumpin455 Transmission - Rearend 5 06-13-2011 12:50 PM
'57 chev speedo w/ 700R4? MattM Transmission - Rearend 3 06-03-2009 07:31 PM
VDO programmable speedo with 700r4 murrsue Transmission - Rearend 6 02-07-2007 05:36 PM
700r4 elect speedo fire power Transmission - Rearend 2 05-06-2005 05:19 PM
700r4 Tailshaft/speedo jrpontiac Transmission - Rearend 2 11-16-2003 07:09 AM
