700r4 speedometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2003, 12:12 PM
700r4 speedometer
I bought a 700r4 transmission for my street rod . (carb) It has the electronic speedometer . Will the mechanical trans. cable drive from a 350 turbo work in my 700r ? If not , how can I convert to cable ? >>>thanks
Old 07-23-2003, 05:42 PM
This has been discussed here so many times you could probably find all your answers in a search.
But....If you have a BOP or buick, oldsmobile, pontiac th350 with a 2" speedometer sleeve then everything will interchange between the two.
If you have a chevy th350 with a 3/4 bullet type speedometer sleeve it won't work nothing will interchange, gears and all. you'll need to get a 2" meachanical sleeve, sleeve retainer, drive gear with it's clip and driven gear (all with the proper amount of teeth for speedo calibration) off an older 700 or a bop th350/th250.
