700r4 spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 12:48 PM
700r4 spring
i was taking out the valve body and other parts, going to install a transgo reprogramming kit.
i noticed the large spring .i guess its the 4th accum.piston spring. is broke in half! anyone know what causes this? or some symtoms of failure? it seemed no different the last time i drove it form when it was just rebuilt.
also anyone know the part number, and place where i can order a new.possibly better spring? thanx
Old 10-16-2005, 03:23 PM
Crosley's Avatar
Wiki Edits: 1659
what you need to watch is for damage to the acc piston and the other surfaces from the broken spring.
many of the TransGo kits have the acc spring in them for the OD.
This is a common item to break in the 700. Why ? I guess poor quaility springs.
Old 10-16-2005, 05:07 PM
thanx crosley, but this kit didnt have the spring. least i didnt see it.any suggestions on where to get one ? and the proper name for it so i dont sound like a dummy when i call the part house? or so the dummys at the parts house know what im talking about
700r4 TV plunger spring AngliaBob Transmission - Rearend 3 01-30-2005 08:17 AM
Rocker to Spring Clearance AFR Springs DTL504 Engine 2 06-02-2004 12:38 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
Proper throttle spring placement willys36@aol.com Engine 1 11-13-2002 07:19 PM
