700r4 stalls car when put in gear?
I have an 82 chevy camaro that had a 305 with a mild cam, the computer in this car has been disconnected and every time I would put it in gear it would die. I replaced the torque converter with a non lockup stock converter and it does the same thing. I now have a 383 with 440 HP and it does the same thing with the same transmission and converter, what is my problem I have been searching everywhere and cannot find anything that fits my problem please help.
I also have a vacum canister on the car and all new vacum lines.
With all the work you have done, It is hard to believe you are having a problem.
If it all works except the car dies when you put it in gear, I would think the idle is to low and when you put it in gear its drop the idle more and stalls out the car. Also vacuum leaks or miss routed vacuum lines would show these symptoms. Or maybe a combination of idle and to retarded timing.. What does it do if you hold the idle up while shifting into gear ¿ |
Stock converter, not sure what cam it's a lunati trying to get the spec sheet from the motor builder, 38 btdc
It idles around 1000 rpm
It won't idle in gear
Again what happens when you hold the idle up when put it in gear ¿¿
Does it drag / bog the motor down. Like the tranny is engaged and lowering the RPM's and trying to move the car ¿? I am not sure what the stall of a shock converter is, but the motor might be idling at a higher RPM than the converter can handle.. |
It try's to take off and dies when put in gear unless you give it gas
That leads me to believe the idle is higher than the stall on the converter. Which makes the trans engage and is putting a drag on the engine.
I would try to lower the idle first before I went and bought a converter with a higher stall. I imagine you trying to drive your beast down the street and having to hold the brake and gas just to keep it running..Lol the guys next to you must be all like...This guy is crazy trying to power brake here on the streets... Lol |
You need a high stall and the distributor advance curve is wrong for the cam.
get a high stall converter based on a smaller 245MM diameter converter. If you want to go fast get a 3500+ stall lock up converter for your th700r4 If you are depending on vacuum advance at idle the timing is going to drop off, when in gear. What is the initial base timing at idle when the vacuum advance is unplugged and you slow the idle speed from 1000 rpm. ? What is the manifold vacuum at 1000 rpm? what is the timing at 700rpm? What is the manifold vacuum at 700rpm? No vacuum advance. |
i have a hughs 3400 stall converter sittin in my shop. n the stall on that stock converter is 2100. by the way what ratio u running in the rearend?
Right now it just has the stock 3:73 rearend
| Tags |
| 700r4, problems, transmission |
| Truck stalls when put in gear? | gowser | Transmission - Rearend | 9 | 08-07-2012 01:17 AM |
| car stalls when put in gear after warm up | Kilrcady | Engine | 16 | 07-04-2011 10:02 AM |
| Engine stalls when put into gear, is it the 700r4 trans? | warrick0209 | Transmission - Rearend | 9 | 10-17-2010 08:09 AM |
| Engine Stalls when put in gear | 63Cad51Hud | Engine | 1 | 04-06-2010 10:34 PM |
| 383 stalls when put in gear | yodert75 | Engine | 6 | 04-12-2007 10:02 PM |
