700r4 stator spline wear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2012, 02:01 PM
Pictures are as accurate as seeing in person but... should it be replaced?
ID:	67692   Click image for larger version
Old 09-01-2012, 04:43 PM
I meant "pictures are not as accurate as seeing in person.."
Old 09-01-2012, 06:47 PM
SSedan64's Avatar
Yes, that needs to be replaced. Make sure you get one with Hardened splines. Many of the older model Stators were not. The hardened Splines will look Blue/Blackened.
It should be pressed in/out, also it should be checked to make sure it's perpendicular to the Pump Body.
Pump, Body & Stator Info here about 1/2 down Pg. 2004R & 700R4 use the same type Pump.
ATTENTION!!!! NEW VERSION!! Strengthening The 2004r | TurboBuick.Com
how hard is it to change stator on 700R4 pump? 350cruiser Transmission - Rearend 1 05-07-2012 01:12 AM
27 spline 700r4 THERACER Transmission - Rearend 1 11-21-2011 03:17 PM
(700R4) 27 spline --30 spline fitment ? vetteman2 Transmission - Rearend 3 02-08-2011 04:54 AM
700r4 pump stator seals blacklabzeke Transmission - Rearend 2 12-08-2007 06:21 PM
700r4 spline question runn141 Transmission - Rearend 1 09-02-2006 06:15 PM
