700R4 sticking in 2nd gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 11:08 AM
chrisape's Avatar
This 700R4 is a 1986 with no aux valve body, it has just been rebuilt. The TV cable is set correct and everything is working great, but it wont downshift to 1st gear. If you take off in O-drive, it goes through the gears great, but when you come to a stop it is stuck in 2nd gear when you take off again. If you manually shift to first it will drop to first gear. I searched on here and found govenor sticking could cause this, but can anybody confirm that this might be the problem? Thanks for any help!
Old 01-01-2007, 11:21 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Could be the governor or the 1-2 shift valve in the valve body.
Governor is easiest to check. Remove the round press-on cover . Check for free movement of the inner valve .
Is this something you have mechanical ability to perform?
Old 01-01-2007, 01:13 PM
chrisape's Avatar
This is my second 700R4 rebuild that I have done, this 1 is just giving me this problem. I think I will just replace the govenor with a new one, and if that doesn't fix it, I guess the valve body will have to come out. Thanks for your suggestions Crosley!, I am still in the learning stages of auto transmissions!
Old 01-01-2007, 02:41 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since there are many different calibrations on governors & Valve bodies... I try to keep the two together when possible.
When you replace one of the two , it can be a challenge to get shift points where they need to be..... not always
Old 01-01-2007, 03:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
One other item on the governor of the 700 / 4L60 trans..
In the photo , at the top of the outer weight you can see a worn in groove. IF this groove is deep enough the inner weight can get stuck in the groove causing down shift problems.
This is not a large cause of shift problems, just one I noticed years ago.
Grind a chamfer on the inner weight in the area that rubs on the outer weight and all is fine.
Also check the retaining nails and weights for wear. Some times the nails wear through.
Old 01-01-2007, 06:45 PM
chrisape's Avatar
Thanks for all you help Crosley, I will post back when I get it figured out! Thanks again, Chris
Old 01-04-2007, 05:01 PM
chrisape's Avatar
Found it was the govenor, the spool inside was gummed up, all is well now! Thanks again Crosley for your advice.
700R4 transmission no 4th gear fivewindowcoupe Transmission - Rearend 2 12-11-2006 12:27 PM
700R4 will not shift into 3rd and 4th gear bebopwally Transmission - Rearend 14 05-25-2006 07:48 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
700R4 whine while in gear only UnionWrkr Transmission - Rearend 10 08-03-2004 12:32 PM
700r4 3rd gear? Mustang_Killa66 Transmission - Rearend 3 03-23-2003 05:32 PM
