700R4 sticks in 2nd - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 11:56 AM
blacklabzeke's Avatar
700R4 sticks in 2nd
After a good highway run the trans will not go down to first gear when coming to a stop. If I manually shift it goes down and then works fine. There never seem to be a problem unless I travel at highway speed for more than an hour. Any suggestions?
Old 10-09-2007, 01:27 PM
jakeshoe's Avatar
Check the governor valve, outside diameter (.800"), and bore.
Old 10-09-2007, 04:47 PM
Are you referring to the valve in the governor assembly?
lost my 2nd gear on a 700r4 why? 1nutwillie Transmission - Rearend 2 02-16-2007 05:48 PM
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
700r4 shifting and 2nd gear . eliotmansfield Transmission - Rearend 4 06-20-2004 03:09 AM
700r4 shift problem,1st to 2nd root Transmission - Rearend 2 10-19-2003 11:31 AM
