700R4 Is stock ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2007, 07:00 PM
700R4 Is stock ok?
I am building my 49 F-1 with a 350 340hp crate motor thru a 700R4 to a 3.70 9 inch rear. I am beyond the street racing days and want smooth power. Mileage matters and I will definitely want the lockup feature. Will my stock 700r4 do the job? If not, what do I need to do or should I do to the trans and converter. My 700R4 came out of an 89 2wd suburban.
Old 08-20-2007, 08:38 PM
it should be ok if your not beating on it. If it has the beast sunshell in it, it will be much more reliable but for what you want it will hold up
Old 08-20-2007, 09:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A quality rebuild and inspection of parts will work for you. These trans ran for thousands of miles in light duty applications.
Old 08-21-2007, 07:25 PM
Thank you both for your responses, I thought that a rebuilt stock 700r4 should meet my needs. It is one of the late ones that should have the better parts. Most posts talk about valve body changes, high stall converters, etc, etc. My sense was that I probably didn't need those changes.
Issue: Stock SBC rod reliability; being able to hold forged Speed Pros above 6000 RPM BringBackTheCamaro Engine 10 01-16-2006 11:07 AM
Turbo 400 or 700R4? leejoy Transmission - Rearend 1 01-02-2006 08:55 PM
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 04:54 PM
700r4 advise chv4me Transmission - Rearend 2 01-24-2004 07:16 AM
700r4 ChevyVan Transmission - Rearend 3 12-22-2003 02:38 PM
