700r4 stuck in 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2006, 06:48 PM
700r4 stuck in 1st
86 s15/700r4 wont shift out of 1st ! please help !
Old 10-18-2006, 07:00 PM
read the posts , will check gov. Trans has 291,000+ on it, hope its not headed south, only being turned by a 2.8.
Old 10-19-2006, 08:24 PM
700r4 stuck in 1st
if you have access to a 0-300 psi gauge you should go to mainline tap,above manual linkage,read pressure in park should be about 70 psi with stock pressure regulator spring,if it is up around 90-95 psi suspect stuck tv valve in valve body,quick test,saves you the hassle of pulling gov.also if it is stuck and you pull the pan,to pull the valve body should be very little debris in pan,or dont bother pulling vb,the valve will stick again.if pan is clean,i will give you good advice on how to keep tv valve from sticking,hope this helps
Old 10-20-2006, 01:38 PM
pulled pan , normal grey colored debris on magnet and pan. pulled gov, small hole in plunger was hard to see lite thru so cleaned it.fluid looks fine.today i am going to clean valve body plungers as best i can without pulling vb and reasemble, am in process of getting press gauge. thank you for your help. gov gear is slightly worn but all teeth are intact, also.
Old 10-20-2006, 01:40 PM
oh yeah, the filter looks very clean, it isnt white but it isnt very grey , either .
Old 10-20-2006, 02:26 PM
700-r4 stuck in 1st gr
this trans used to be trans shops bread and butter.but 10 to 20% of these units would have problems with sticking tv valves after rebuild.10 years ago i started installing transgo jr shift kit in each one,no more problems.they have redesigned tv valve that will not stick,also cleaning the plunger wont do it the tv valve is deeper inside the vb,cant come out because of roll pin accessible only when vb is down.i think its time to say hi to jr.
Old 10-20-2006, 02:37 PM
700r-4 stuck in 1st
if you dont want to spring for the kit,we used to drill the tv balance hole in the shift plate,small hole over top of tv valve,we drilled it to .063 this works most times.why this works?well its a hydraulic thing,but it does work.if you need me to fax you a picture of the plate with hole location i will be glad to
Old 10-20-2006, 03:38 PM
thanks for your help ! i dont have a fax here .i intend on using a little contact cleaner on the plungers and some compressed air. before i remove the vb i am going to put the gov and pan back on and try the "20-30 mph / goose the pedal" trick the raptor site talks about . if that doesnt work , well i gess the next step is the vb. i have the factory service manual for my 87 z-28 and maybe i can locate that hole from those diagrams. will post later, and again, thanks for your input !
Old 10-20-2006, 03:44 PM
after checking my records, i put a "transgo shift fixer" (?) kit in this vehicle about 29,000 miles ago,i kept all the old parts. it has mostly hiway miles on it and i gave this truck to my nephew 1.5 years ago, he drives it only locally. pretty sure he doesnt 'romp' on it.
Old 10-20-2006, 06:37 PM
Well, Every Tyhing Seems To Be Working/shifting Ok, Dont Have The Lock Up Working Though. Will Work On 2morrow When Daylight.
Old 10-20-2006, 06:38 PM
oh yea, didnt need to do the 20-30 mph goose the pedal thing.
Old 10-26-2006, 04:53 PM
cleaned elec plug on lh side of trans, running/shifting fine again, thanks for the help !
1st tech Post (probably discussed to death) T350 and 700R4 conundrum Kallie49 Transmission - Rearend 5 01-06-2007 12:23 PM
700r4 tranny not shifting out of 1st dmd02769 Transmission - Rearend 3 09-21-2006 10:45 PM
700R4 stuck in First gear redvette Transmission - Rearend 3 02-13-2005 10:12 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
700r4 not shifting out of 1st gear AKGMC Transmission - Rearend 2 06-08-2003 05:27 PM
