700R4 stuck in 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2012, 04:46 AM
700R4 stuck in 1st
I have a 1988 700R4 out of a 1500 I just rebuilt. I put if back in and it worked fine for a couple of days, then it wouldn't shift out of first until it got warm.
I put a transgo shift kit in it hoping that would fix it. It didn't. So now I took it back out and all the way apart. I don't see anything wrong.
Does anyone know what is making it do this?
Old 05-03-2012, 04:59 AM
First check tour TV cable and make sure its adjusted right. Next you will have to pull the valve body and check the TV valve and the shift valves and make sure nothing is sticking. Also your governer valve could be stuck. Pull the governor and look at the gear and make sure its not chewed up. Also hold the governor so the gear is pointing up and move the weights open and closed and see if the valve moves up and down.
Old 05-03-2012, 05:02 AM
I forgot also if you pull the valve body make sure you used the right valve body gaskets. Make sure no holes are covered by the gaskets.
Old 05-03-2012, 05:13 AM
Thanks for the reply,
The valves are all free, I just updated the springs in them. I'll look at the governor today. The gear looked ok, but I haven't rechecked its movement. I don't understand why that would go bad. I know its the right gasket I triple checked that.
Old 05-03-2012, 05:24 AM
Just takes a tiny bit of debris to stick a valve.
Old 05-03-2012, 02:54 PM
Follow up
I looked at the governor today. It seemed like it moved freely until I compared it to another one. The old didn't move the last little bit where the outside plates pull away from the inside. Also there wasn't a pin in the gear. So I'm gonna put this other one in and see if it does any better.
Transmission stuck in 1st ? mannasugar Transmission - Rearend 1 06-01-2009 03:46 PM
TH350 stuck in 1st???? Ichoptop Transmission - Rearend 14 05-11-2007 08:01 AM
New 700 stuck in 1st- Gurus to help Newbe Dan89rs Transmission - Rearend 4 11-16-2006 08:39 PM
700r4 stuck in 1st bigjetmech Transmission - Rearend 11 10-26-2006 03:53 PM
700r4 Stuck in first busted 700r4 Transmission - Rearend 1 07-09-2006 08:33 PM
