700r4 Stuck in first - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2006, 07:40 PM
Hey everyone im trying to get my 90' camaro iroc back on the road. The trouble is that we lent it out to a friend and she found some way of tearing the transmission up instead of switching to second it just keeps locked in first. I have tried to switch it manually and that dosnt work either. Instead of switching it just runs up the rpm's, and if you come off the throtle it dosnt drag down it acts like its in neutral and drops down to idle. I hope someone out there can help me out I love this car too much to bear watching it sit. thank you
Old 07-09-2006, 08:33 PM
Crosley's Avatar
Wiki Edits: 1659
check TV cable adjustment.....
possible broken govenor gear ( plastic)..... under a round press on cover near back of main case , drivers side
2wd to 4x4 700r4 QUINTANA64 Transmission - Rearend 7 04-05-2006 05:20 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
700R4 stuck in First gear redvette Transmission - Rearend 3 02-13-2005 09:12 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
700R4 vs. 2004R 81ElCaminoGuy Transmission - Rearend 2 08-21-2002 01:10 AM
