Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 is stuck in first gear.
Old 12-05-2012, 05:51 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
The 700R4 isn't the easiest Trans to start out with if you've never built one. I suggest investing in a Rebuild/Overhaul video and an ATSG Manual to help you along.
One tool that is needed is the rear clutch spring compressor tool and a good set of Lock-Ring pliers. Other things/tools can be used for most parts. Should replace all the Bushings, Trans Shop will do it fairly cheap.
https://www.700r4l60e.com/store/home.php?cat=63
Dana @Pro-Built can put together a good Build kit for you or other Co.'s
www.CKPerformance.com
700R4 Transmission Parts GM Rear Wheel Drive
https://www.wittrans.com/Schematic.a...smission=700R4
700R4 transmission parts 700R4 transmission kits
