-   -   700R4 is stuck in first gear. (http://www.hotrodders.com/forum/700r4-stuck-first-gear-225469.html)
chevymanwithaplan 10-27-2012 07:28 PM
Can anyone help me out. my 1990 K2500 4X4 is stuck in first and I am looking for tricks ideas and maybe some help. I can give a complete run down of what everything is doing it is needed to know.
Thank you
blacklabzeke 10-27-2012 08:24 PM
Check the gear (plastic) on the governor and the valve inside the governor asembly.
Ruthlessmr 11-01-2012 07:58 PM
does it have reverse?
rustman 11-01-2012 09:38 PM
Check to see if the vaccum modulator hose slipped off. On my TH400 it is on the right side of the trans housing.
Ruthlessmr 11-02-2012 06:29 PM
if its a 700 there is no modulator
chevymanwithaplan 11-09-2012 11:09 PM
700R4 wont shift
Yes it has reverse and I adjusted the TV cable to its specks.
I bought a new govenor just have to put it in yet.
chevymanwithaplan 11-09-2012 11:14 PM
700R4 wont shift
I bought a new govener and have yet to put it in. I hope it fixes the problem. Cause spending $50 to get a new govenor is pricey but did it anyways just got to drop the front drive shaft and put the new one in.
ASE Doc 11-29-2012 08:26 AM
It could also be a stuck 1-2 valvetrain in the valve body. I had one apart(cast iron VB) and cleaned up the 1-2 shift valve train then added lubeguard red to new fluid and it was fixed. I seem to remember another one with an aluminum valve body that needed to be reamed and an oversized valve installed.
chevymanwithaplan 12-03-2012 01:55 PM
I took it apart and bad news for me.....
I dumped $50 into a new govenor and pulled the pan to find my tranny fluid was black and there was tons of clutch pieces in the bottom of the pan. Now on to finding a good cheap used 700R4
chevymanwithaplan 12-03-2012 02:43 PM
How hard is it to rebuild a 700R4 from top to bottom. I have the OEM factory Books made for my 1990 chevy. But I have never rebuilt a tranny before and the book shows everything just looks complicated.
SSedan64 12-05-2012 05:51 AM
The 700R4 isn't the easiest Trans to start out with if you've never built one. I suggest investing in a Rebuild/Overhaul video and an ATSG Manual to help you along.
One tool that is needed is the rear clutch spring compressor tool and a good set of Lock-Ring pliers. Other things/tools can be used for most parts. Should replace all the Bushings, Trans Shop will do it fairly cheap.
https://www.700r4l60e.com/store/home.php?cat=63
Dana @Pro-Built can put together a good Build kit for you or other Co.'s
www.CKPerformance.com
700R4 Transmission Parts GM Rear Wheel Drive
https://www.wittrans.com/Schematic.a...smission=700R4
700R4 transmission parts 700R4 transmission kits
