Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700R4 stuck in First gear
Old 02-13-2005, 06:04 PM
redvette redvette is offline
what I found
Okay I got the governor out of the trans(700R4) and the plastic gear on the end of the governor was stripped and broken at the rollpin. Is this just a common thing for this trans?? Is there a metal replacement gear or is the way the trans is designed the plastic stops other wear which is worst to repair? Also since I don't see the plastic parts in the pan, am I goning to have to fins them?? Thanks
