700r4 "stupid" question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2005, 01:26 PM
well, here's my problem with my 90 chevy truck with a 5.7liter, the reverse gear in my tranny is gone, and i wanted to replace my 700r4 with another, not sure if all 700r4 trannys are the same.
I saw a couple of used 700r4 for a V-8 camaro, and wanted to know if it's a direct swap into my V-8 truck...or is it a different bolt pattern, and gear ratio, what about the tailshaft and splines??? I don't really understand transmsisions, but i have to start somewhere....hopefully with your help I can do this....
I'm not a mechanic, but I'm willing to try to save me some cash....as you know times are tough. thanks
Old 10-05-2005, 03:35 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome again! This forum is for introductions, If you will post your questions in the proper forums on the board they will have a better chance of being seen and thus more answers.
Old 10-05-2005, 07:52 PM
poncho62's Avatar
Wiki Edits: 5
Moving to tranny eorum...........
Old 10-05-2005, 09:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the internal electrical harness & pressure switche(s) would probably not be the same as you need for your application.
700r4 ID question amdg3 Transmission - Rearend 4 09-02-2005 06:42 AM
700r4 question Anton Transmission - Rearend 2 07-08-2005 05:02 PM
700R4 Mounting Question mike bryan Transmission - Rearend 6 11-05-2004 05:14 PM
700r4 band question chevcamz28newbie Transmission - Rearend 0 08-05-2003 12:46 AM
700r4 Front Pump Question ChevyCam Transmission - Rearend 13 03-15-2003 07:23 PM
