700r4 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2005, 02:13 PM
700r4 swap
i have a 81 monte
original motor was a 4.4(267ci)
i have replaced that with a 383
i want to put in a 700r4 in place of the 350 tranny(non-lock up)
i have a 700r4 from a late 80's camaro
have looked at a few sites touching on the subject
is there any way to tell the difference between a 700r4 and a 200r4?
and how much will the drive shaft have to be shortend
i also have a 3.73 limited slip out of an el camino(an A-body right?)
and an A body to a G body kit for that
what other mods to drive shaft would i have to do (if any) to get that to fit
move the crossmember back
just wondering if anybody has done this all ready or knows more about it than i
i'm a pretty good mechanic i beleive almost anything can be done
but i have not done this so tring to make it as easy as i can
any feed back will be a plus
thanks
meuhus
Old 07-26-2005, 06:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Read this STICKY at the top of the amin tranny/rearend page.
Photos and some information there may help you on tranny ID
Originally Posted by meuhus
i have a 81 monte
thanks
meuhus
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
