700r4 swap manual to automatic - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2009, 07:03 PM
I Have A 4-speed Manual And Purchased A Rebuilt 700r4 To Replace It.
So I Can Get Overdrive. The Rearend Is 411 . Can Anyone Tell Me Is This Just A Bolt In Project Or Does Anything Need To Be Modified ?
My C-10 Truck Has 350 In It And The 700r4 Is Coming Off A 350 .thanks.
Old 01-04-2009, 07:45 PM
Roddin in OK
Last journal entry: Still Moving Forward
Swap
This swap does take a little doing.First the shifter,You'll need a floor shifter for an automatic. if it has a column shifter,you can hook it to that [i've done it] but it's a bad idea. I ran my 62 Chevy into a Mercedes one time because there's nothing to keep it in park. You'll need a auto. flywheel ,Also you will have to move the cross member and if it's never been moved,that means grinding off rivits.The Drive shaft yoke will have to be changed and i'm pretty sure you'll have to have it cut down a little, on that measure center of u-joint to center of u-joint and leave an inch or so of slide.Then you'll have to get a bracket to hook up your TV cable to the carb or throttle body.The Torque convertor needs to lockup in 4th so you'll need to hook up a switch ,prefferably a vac. switch.There's also the speedo cable to deal with. The right cable and gears with have to be figured out. I think that about covers it.maybe someone else can add anything i forgot. Good Luck
Old 01-04-2009, 08:06 PM
Thanks , The Shifter I Can Do, And The Mount , I Will Get A Profesoinal To Cut Down THE DRIVESHAFT For Me
Old 01-04-2009, 08:13 PM
Roddin in OK
700 oh 700
You'll be happy with the 700.If everything is set up right they'll last a long time and the first gear is awesome. Good luck and Happy rodding!
700R4 – Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
TH350 swap to 700R4 Rydog89 Transmission - Rearend 6 12-26-2007 05:29 PM
Which would be preferred for a 1927 Model T: Manual or Automatic transmission? jesseeee Transmission - Rearend 5 02-17-2006 07:39 AM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
