-   -   700R4 swap to a T-400 ? (http://www.hotrodders.com/forum/700r4-swap-t-400-a-180016.html)
JoelHMcCarter 06-24-2010 02:47 PM
I recently bought a 1986 C10 Silverado with a 305 motor and a broken 700R4, All i have to replace it with is a THM400. Can anybody tell me if it will be a direct fit or if ill need to change my driveshaft / Crossmember / and tranny mount? -Thanks
Crosley 06-25-2010 09:43 PM
:pimp:
Not a direct fitment. cross member is moved , drive shaft length is different, drive shaft Yoke is different(larger = 32 spline) on most t-400 short shaft trans
454headache 06-26-2010 03:49 AM
Regardless, you'll love the TH400. Strong as an tungsten ox transmission. It will survive a 40mph shift into reverse, ask me how I know... :rolleyes:
Oh yeah, don't forget to hook up the downshift electrical connection on the th400 when you do swap it.
