700r4 t0 350 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2007, 01:23 AM
700r4 t0 350 swap
i have a 89 caprice and i want to know how to hook up the vacume for the module on the tbi any info
Old 12-25-2007, 06:24 AM
A 700R4 does not require vacuum ... like a Turbo 350 does ... The 700R4 has NO vacuum modulator.
EDIT ... I thought you were wanting to upgrade to a 700R4 ... NOT go backwards to a Turbo 350 ...
I misread your question
Old 12-25-2007, 06:29 AM
Crosley's Avatar
Wiki Edits: 1659
IF you are bolting in a t-350 to replace a 700r4/4L60 trans... you need a direct vacuum feed from the engine.
A vacuum gauge will help you locate this.
Old 12-25-2007, 06:42 AM
31 five window
Last journal entry: Moving along with patch panels.
You can TEE into where your power brake booster gets its vacuum.
Old 12-25-2007, 01:50 PM
Do NOT use the PCV line. It's not true vacuum, and it will make it not shift right.
V6 or V8 700R4 swap? cacsmret Transmission - Rearend 4 05-05-2006 09:28 PM
1978 grand prix chevy 350 swap threesand9s Engine 10 06-29-2004 12:43 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
