700r4 tail shaft cracks / problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 07:59 PM
i just picked up a 700r4 trans & i just noticed the tail shaft has little cracks on it. could i still run the trans like this?
Name:	2012-09-16 17.45.28.jpg
ID:	67923   Click image for larger version
Name:	2012-09-16 17.46.15.jpg
Old 09-16-2012, 10:47 PM
you will have to put a seal in it so when its out look it over.If questionable replace it
Old 09-17-2012, 05:49 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
your end shot photo clearly shows that tail housing is junk
The Following User Says Thank You to Crosley For This Useful Post:
the82elco (09-17-2012)
Old 09-18-2012, 01:57 AM
Wiki Edits: 85
I don't see any cracks in the tailshaft.
Old 09-18-2012, 08:24 AM
SSedan64's Avatar
X2^^, Looks like the Slip Yoke put a beating on the Bushing and ovaled out the opening
Old 09-18-2012, 12:50 PM
on the housing
700r4 Tail Shaft fit a t-350 ? monk250 Transmission - Rearend 4 05-12-2009 07:53 PM
Question on 700r4 transmission tail shaft and front shaft eric32 Transmission - Rearend 11 05-10-2009 12:03 PM
tail shaft ?'s bowtieboy792003 Transmission - Rearend 0 05-26-2008 03:49 PM
C6 tail shaft darrin Transmission - Rearend 2 07-13-2003 09:06 AM
replacing 700r4 in f-body with th350 with 9"tail shaft striker86 Transmission - Rearend 6 05-25-2003 08:48 AM
