700r4 tail swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 05:31 PM
crossfire84's Avatar
Tri-Powers are cool
700r4 tail swap
hello, i have a 1984 700r4 from a corvette. i need to know if i can swap the tail section off this and put a non vette tail section on ? the trans mounts are totally different. please no tire kickers, some one must have this info. thank you for your help.
Old 06-03-2005, 06:15 PM
Crosley's Avatar
Wiki Edits: 1659
don't know if I am a tire kicker;
any 700r4 tail housing will bolt on ......... BUT A vette tail hosuing is shorter than a standard tail housing
If you have a real vette tranny , the output shaft has been cut a little shorter than a standard output shaft. This is fine, the shaft will just be right at the end of the tail housing seal, all is good.
the speed-O gear clip on a vette tranny is located in the rear hole of the TWO holes on the output shaft.... with a NON vette tail housing the speed-O gear must be moved to the front hole. Don't move it and the gears tear themselves up
IF you have a vette tranny case , you need the tail hosuing with the mount holes on it.
hang onto the vette tail housing, people buy them $$
Old 06-03-2005, 06:20 PM
BigDawgsEatFirst's Avatar
400SBC4Life
No Tire Kickers
.................HA,Ha
Old 06-04-2005, 11:09 AM
Tri-Powers are cool
700r4
thank you crosley for the info, now it"s off to the junk yard, woo hooo again thanks
Old 06-04-2005, 11:20 AM
Tri-Powers are cool
700r4
wow crosley went thru your photo album, i assume this is what you do. isn't it great to have a machine shop at your finger tips?
th350 to 700r4 swap?????????? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
4x4 700R4 to 350 swap Davesblazer87 Transmission - Rearend 4 12-22-2003 07:59 PM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
Can you swap tail shafts on TH350s? briwill Transmission - Rearend 5 12-11-2002 08:36 PM
