700r4 Tcc ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2007, 02:48 PM
47 Coupe's Avatar
700r4 Tcc ?
I was driving my 1991 GMC 5.7/ 700R4 with my scanner hooked up this morning. I noticed that going down the highway 65-70 mph, the TCC light is lite up showing the converter is locked up. When I would let off the gas the light would go out (converter unlocked), when I got back on the throttle the converter would lockup again.
Is this the normal operation?
Old 12-02-2007, 08:34 PM
Crosley's Avatar
Wiki Edits: 1659
some what common.
Old 12-02-2007, 08:38 PM
GM changed operational parameters on later vehicles to allow TCC disengagement on "lift throttle". This allows the vehicle to slow without creating a chuggle or posting effect, ie. the trans driving the engine as would happen at slower speeds with the TCC on.
Old 12-02-2007, 09:32 PM
47 Coupe's Avatar
Thanks for the replies. I kinda thought it was like freewheeling.
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 01:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
700r4 is fluid routed to cooler when TCC is off eliotmansfield Transmission - Rearend 3 02-12-2006 06:56 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
