Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tci valve body
Old 09-28-2008, 11:59 AM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
What is being talked about in the original post is a ; "constant pressure " valve body.
TCI modifies a v-body for full main line pressure all the time. The TV circuit still operates as original with shift timing changes as the cable is pulled .
THe problem with the constant pressure v-body is line pressure is very high all the time. Depends on the boost valves installed to the max pressure that is reached. I have seen 320psi max pressure with the large boost valves installed.
High pressure creates harsh shifts , harsh engagement , higher oil temps.
