Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tci valve body
Old 09-28-2008, 04:50 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Crosley's right, And it adds more pump strain & wear. Since the TV cable doesn't control line pressure with the Constant pressure VB even part/light throttle shifts are harsh.
If you're are having problems setting the TV cable correctly you should check out BTO's TV Made Easy setup. They have very thorough Info, directions & parts.
Read through this and it will help explain all the settings.
http://www.tvmadeez.com/article/index.php
