Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tci valve body
Old 09-28-2008, 09:47 PM
adrules12 adrules12 is offline
the 700r4 isue..
yup the knowledge out there is flowing the first break was a drum the name is escaping me it is heald in place w a large c type clip and has teeth it shattered some of the teeth which made it fall out of place...this time i was going down hill and wasnt into it just cruising and it started to make rattling noises as if something came apart and then nothing ...pulled over shut it down went to re start and it dragged so hard wouldnt start...thought the coverter bolts may have loosened but nope let it cool and it did start...maybe the converter let go...just havent had a chance to pull the tranny but my builder was concerned that constant pressure could be an issue and yes it was a very firm shift no matter rpm...thanks for the in put will let you know after the tear down what is found. you guys have given some things to consider...adrules12
