Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4 tci valve body
Old 10-22-2008, 11:00 PM
adrules12 adrules12 is offline
700r4 bent flex plate
well went to put the re built 700r in and found the flex plate was tweeked....what would cause it to be bent in toward the motor ? in other words the out side of the flex plate was bent towards the engine ....guess this had something to do w my pump failure ...not sure if the converter kicked off the series of events or what ? will be going w a heavy duty flex plate and take it from there...any thoughts about the cause of this ? thanks , adrules12
