700r4 to th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2006, 07:12 PM
Drive Fast, Take Chances!!
700r4 to th350
I have a 1986 GMC K1500 4x4 pickup. it has a 305 and a 700r4 tranny. I might put a 383 with 380 hp in it. The 700r4 in it is very tired and I have a th350 in my garage. The th350 is built to withstand 1000 hp. I am going to put it in but before I start I need to make sure the tranny can fit in my truck. Anyone that can help me please do, I have some expierence but I do not know the specs on this subject.
thanks
Matt
Old 06-26-2006, 08:16 PM
Crosley's Avatar
Wiki Edits: 1659
thanks
Matt
it is not a direct bolt in replacement
there was a kit around with a spacer and cut down 6 inch 2wd output shaft to install a t-350 in place of a 700 tranny.
Old 06-27-2006, 06:45 AM
4wd
it is a 4wd pick-up though does that matter?
Old 06-27-2006, 06:13 PM
Crosley's Avatar
Wiki Edits: 1659
Yes,
that is the kit I talking about.
A t-350 will NOT bolt directly in place of a 700/4L60 tranny in a 4x4 application
With the mentioned kit.... your drive shafts and cross members can remain in same installed place.
I installed many of these kits back in the mid & late 1980's when we removed more 700 trannys that we rebuilt.
visit this page:
fitz-all
Old 06-28-2006, 09:02 AM
thanks
thanks Crosley for the help that kit looks like it will work perfectly for my application.
thanks again, matt
Old 07-03-2006, 05:06 PM
fast68's Avatar
likes chevy trucks & boobies
well he never did say if the th350 is a 4x2 one or a 4x4 one
its a simple swap if its a 4x4 one both are 27 splines and everything, very easy, dont need any retrofit stuff
good luck
Old 07-03-2006, 06:43 PM
Crosley's Avatar
Wiki Edits: 1659
good luck
Your information is incorrect.
A 4x4 t-350 tranny will not bolt directly in place of a t-700 4x4 tranny.
The main cases are different lengths , the drive shafts and cross members would need attention.
The length of the 4x4 output shafts that extend past the rear edge of the tranny case are different from a t-700 & t-350.... which requires a different design on the t/case adapter
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 08:19 PM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
th350 low roller clutch and 700r4? Tissue Transmission - Rearend 4 05-16-2004 10:23 AM
85 camaro 700r4 to th350 drewkuch Transmission - Rearend 5 11-09-2003 09:48 AM
700r4 vs th350 chevcamz28newbie Transmission - Rearend 2 08-02-2003 07:20 AM
