700r4 to Th350 or Th400?..plz read - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2002, 03:57 PM
Rubberman2003's Avatar
Post 700r4 to Th350 or Th400?..plz read
Ive got an 84 Z28, im putting 350 in it...i looked in a YearOne catalog and i can get a conversion kit so i can put a th350 or 400 in it which would u recamend? i know with the 400 i would have to get the short drive shaft, the car will be driven on the street but i will be taking it to the track sometimes
Old 10-06-2002, 04:30 PM
Post
A Turbo 350 takes less HP to turn.
A Turbo 400 takes less abuse
You make the call......
Old 10-06-2002, 08:37 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
Post
What Deuce Roadster is saying is:
The TH350 takes less HP to turn, but can't handle as much as the TH400.
It does depend on your application. How much power and torque are you going to be putting to it?
Jason
Old 10-06-2002, 08:46 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I have seen th350's run behind 800 HP big blocks. They have to be built correctly for that, but for a street 350 go with the th350. No use in adding the weight and loosing the extra 15 HP to turning the th400 pump.
Chris
Old 10-06-2002, 09:18 PM
bonuts's Avatar
Got Ouzo for touzo
Post
I agree totally with all the responses, go with the th350.
bonuts
