700r4 to th350 transmission conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2003, 05:02 PM
Post 700r4 to th350 transmission conversion
Anyoneknow how to or where I can get a conversion kit to change a 700r4 to a th350 in an 84 camaro.
[ January 10, 2003: Message edited by: Ralph Horak ]
[ January 10, 2003: Message edited by: Ralph Horak ]</p>
Old 01-11-2003, 03:37 AM
Post
summit.com or jegs.com
Old 01-12-2003, 10:23 AM
80 ZZ4-Z28's Avatar
New Member
Post
Not sure about the conversion kit, but you will have to use a TH350 with a long tail shaft unless you want to exstend your drive shaft. I put a 700R4 in place of a TH350 in my 80 Z28, I just moved the cross member back and drilled new bolt holes in the frame, and had my drive shaft shortend.
