700r4 Torque converter Chatter(no gears) upon installation
Here is exactly what happened:
Had a 700r4 rebuilt and purchased a new torque converter from the same shop. Before raising the tranny up behind the 400sbc I had to stab the torque converter onto the transmission. I could tell it wasn't going all the way in so I rotated the torque converter so that the two grooves lined up with the to notches I could see inside the transmission behind the front seal. Bingo it slid in further and I figured I did right,I couldn't get my fingers in between the converter and the tranny-front to reach the seal, it still seemed like it should have gone in a little further, but I didn't think that the seal should be completely butted up against the weld of the torque converter. So I raised it behind the sbc, a little too high I am sure because I know I got the converter in a bind with the flexplate. I tighteded the bellhousing up the the motor and I heard a ding, so I backed off and lowered the tranny a hair or two. Then she mated perfectly. I tightened the 3 short bolts on the flexplate to the converter.I had put a full quart of ATF in the torque converter prior to placing it on the tranny. I put 6 quarts in through the dipstick, then turned her on, I heard chattering right by the torque converter, so I killed it immediately, maybe ran for 15-20 seconds. Took the converter dust cover off. and ran it again for 30 seconds. Still chattering. Added 5 more quarts while it was not running, then ran it for half a minute, checked to see if it would shift,NO GEARS what so ever, killed it, then later ran it again for about a minute, gave it a little rev to see if the pump just needed to fill up or the filter needed to be saturated. The level went down some the last two times I ran it. Gentlemen I'm about to cry, and I am a man, men don't cry. Do I take the tranny out and restab the torque converter, or take it all the way out and take it back to the shop. Heard I should back off the flexplate bolts, but they'd rattle loose Im sure of it.I am worried the torque converter punched a hole in whatever it touches in the tranny when I had it in a bind, wasn't a bad bind though. Let me hear your two cents please, I've hunted the net, so I would not bother you boys, but here I am. Thanks for all your help in advance! |
I hate to tell you this but, I think you may have broke the Rotor in the Pump and it will probably have to come back out. That ping you heard was probably the Rotor snapping.
Read this thread>> did I break the pump? there's a Pic of a broken rotor Crosley posted in this Thread. Last edited by SSedan64; 01-26-2011 at 09:19 PM. |
thanks for the info, I will be pulling it out tomorrow evening, I will shine a light in the seal to see if there are any broken pieces, I just don't think I put it in that much of a bind, but I don't know how delicate the internals of a tranny are. I paid someone to rebuild it. I was told to take one of the cooler tubing off to see if the trans is pumping ATF, even if it is, that chattering has got to be a problem? Unless it will shut up after I run it for a while? Anyway I will report the outcome after tomorrow evenings disection. Thanks again for the comments and links to info.
When you install the converter, you need to rotate it & press in on it. Should feel/hear 3 clicks. The Input Shaft splines, Stator Support splines and Pump Drive Lugs/Splines need to engage.
You should have 1/8" to 3/16" clearance between the TC & Flexplate before sliding the TC forward to bolt it to the Flexplate. If not it's not fully/correctly installed/seated. You either have a Pump problem or internal TC problem. |
got her out, yes there were broken pieces, looked just like the pump pictures you forwarded me to. The shop is going to look at it for me, hope it doesn't need an entire rebuild, only ran for 2 minutes 15-30 second intervals. Seriously, thanks for all your help.
Sorry to hear that. At least you know now what the chatter is. After you get it fixed up and get er' back up to the engine, re-check that the converter is still all the way in. (I really don't think I need to tell you that now
).DON'T DO THAT AGAIN! Good luck, thanks for the quick update, and let us know when you get it going.
| 700r4 torque converter | best47 | Transmission - Rearend | 2 | 01-07-2011 08:21 PM |
| 700r4 Torque converter | retiredmodman | Transmission - Rearend | 2 | 03-29-2009 10:14 PM |
| Anyone have a 88 700R4 valvebody installation torque sequence? | Hotwire | Transmission - Rearend | 4 | 08-15-2008 06:46 PM |
| new wiki article: Torque converter installation error fix | Jon | Transmission - Rearend | 0 | 06-12-2008 03:15 PM |
| 700R4 torque converter | HURSTW25 | Transmission - Rearend | 3 | 09-28-2004 07:07 PM |
